Ana içeriğe geç
MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
    FixBot'a Sor
    Yorum Ekle
  2. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 2, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 2, 2 resimden 2.
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
    FixBot'a Sor
    Yorum Ekle
  3. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, Battery Connection: adım 3, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, Battery Connection: adım 3, 2 resimden 2.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    FixBot'a Sor
    Yorum Ekle
  4. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 4, 1 resimden 1.
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    FixBot'a Sor
    Yorum Ekle
  5. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, Fan: adım 5, 3 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, Fan: adım 5, 3 resimden 2. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, Fan: adım 5, 3 resimden 3.
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
    FixBot'a Sor
    Yorum Ekle
  6. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 6, 1 resimden 1.
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
    FixBot'a Sor
    Yorum Ekle
  7. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 7, 1 resimden 1.
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
    FixBot'a Sor
    Yorum Ekle
  8. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, Logic Board: adım 8, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, Logic Board: adım 8, 2 resimden 2.
    • Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
    • Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  9. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 9, 1 resimden 1.
    • Disconnect the camera cable from the logic board.
    • The camera cable slides out from its logic board connector. If your cable feels fragile, use a spudger to walk the cable out from the metal tabs on each side of the connector head.
    FixBot'a Sor
    Yorum Ekle
  10. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 10, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 10, 2 resimden 2.
    • Disconnect the following four cables:
    • AirPort/Bluetooth cable
    • Optical drive cable
    • Hard drive cable
    • Trackpad cable
    • To disconnect the cables, use the flat end of a spudger to pry their connectors up from the sockets on the logic board.
    FixBot'a Sor
    Yorum Ekle
  11. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 11, 3 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 11, 3 resimden 2. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 11, 3 resimden 3.
    • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
    • The cable may be difficult to insert. If you are having trouble, temporarily attach a piece of tape to the cable to help you guide the cable into the socket.
    FixBot'a Sor
    Yorum Ekle
  12. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 12, 1 resimden 1.
    • If present, remove the small strip of black tape covering the keyboard backlight cable socket.
    FixBot'a Sor
    Yorum Ekle
  13. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 13, 3 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 13, 3 resimden 2. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 13, 3 resimden 3.
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
    FixBot'a Sor
    Yorum Ekle
  14. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 14, 1 resimden 1.
    • Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  15. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 15, 3 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 15, 3 resimden 2. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 15, 3 resimden 3.
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    FixBot'a Sor
    Yorum Ekle
  16. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 16, 1 resimden 1.
    • Remove the following nine screws:
    • Five 3.6 mm T6 Torx screws
    • Two 4.3 mm T6 Torx screws
    • Two 7.2 mm T6 Torx screws
    • In some models the screws may be slightly shorter as follows:
    • Five 3.0 mm T6 screws
    • Two 3.6 mm T6 screws
    • Two 6.7 mm T6 screws
    FixBot'a Sor
    Yorum Ekle
  17. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 17, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 17, 2 resimden 2.
    • Remove the following two screws:
    • One 8.6 mm Phillips screw
    • One 5.5 mm Phillips screw
    • Remove the display data cable retainer from the upper case.
    FixBot'a Sor
    Yorum Ekle
  18. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 18, 1 resimden 1.
    • Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
    FixBot'a Sor
    Yorum Ekle
  19. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement: adım 19, 1 resimden 1.
    • Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
    • Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
    • Remove the logic board.
    FixBot'a Sor
    Yorum Ekle
  20. MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement, MagSafe DC-In Board: adım 20, 1 resimden 1.
    • Pull the MagSafe DC-In board cable toward the heat sink to disconnect it from the logic board.
    • Do not pull upwards. Pulling the connector upwards may break the socket from the logic board.
    • Remove the MagSafe DC-In board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
130 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
515.338 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
28.236 adet Kılavuz yazıldı
12Kılavuz Yorumları
Piece of cake, took an hour or so, but I was being extra careful. The only sticky part were the backlight cable and the keyboard ribbon cable ZIF socket, those two items I found fiddly to get re-inserted properly. Thanks for the tutorial.
Alan Gates - Yanıt Paylaş
Thank you Andrew Optimus Goldberg,
It is super guide & explanation - funny part is, now i am left with one screw, couldn’t find its spot :), I shall fix it later.
Thanks again
Mitesh - Yanıt Paylaş
Thankyouuuu your guide very helpfull
Here's some tips to avoid left any screw : use a transparant tape with the sticky note and write or give the code…
I ussually give 3 layer of tape and devide into several sticky note… :)
Bayu Indraa - Yanıt Paylaş
Excellent guide! My seven-year-old Macbook now charges again without me having to tighten the power cable at weird angles!
The hardest part of this repair was getting the microphone out. That thing was glued in tightly, the rubber shroud is hard to grip through, and the little wires are so delicate!
Thomas - Yanıt Paylaş
Worked like a charm! Take your time. Directions were great but some of the connections were a little fiddly. Pay close attention of exactly how the connectors come apart. For these 67 year old eyes, a magnifying glass would have been handy along with some tweezers to replace fat fingers for getting some of the connections started.
robert jones - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 65
Son 30 gün: 247
Her zaman: 75,672
