Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
You can again use ExpressCard accessories by replacing a faulty ExpressCard cage.
Neye ihtiyacın var
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Bir başkası bu kılavuzu tamamladı.
