Giriş
Use this guide to replace a damaged front display bezel.
Parçalar
Hiçbir parça belirtilmedi.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the three antenna cables attached to the Airport Extreme card.
Remove the two 5 mm Phillips screws from the lower left and right corners of the display (two screws total).
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
Rotate your spudger toward the rear bezel to separate it from the front bezel.
If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
Remove the pieces of yellow kapton tape from the bottom left corner of the display.
Remove the pieces of tape securing the display data cable and camera cable to the display.
Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
Remove the piece of tape securing the camera cable to the LCD.
Lift the inverter out of the clutch cover.
Disconnect the inverter cable from the inverter by pulling its cable away from the socket on the inverter board.
Remove the inverter and set it aside.
If you have a Core Duo machine, refer to picture 1 and remove three Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
If you have a Core 2 Duo Model A1211 machine, refer to picture 2 and remove two Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
7 farklı kişi bu kılavuzu tamamladı.
