Giriş
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Parçalar
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Disconnect the PRAM battery cable from the bottom right corner of the logic board.
8 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Great Guide! Thanks! Got the weakened BIOS/PRAM changed, without having to touch the m/b at all, very fine!
