Giriş
Removing a few screws will remove this part and allow access to your RAM.
Aletler
Parçalar
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm PH000 Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
19 farklı kişi bu kılavuzu tamamladı.
