Ana içeriğe geç
MacBook Pro 15" Core Duo Model A1150 RAM Replacement
Neye ihtiyacın var
    1. MacBook Pro 15" Core Duo Model A1150 RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 15" Core Duo Model A1150 RAM Replacement, Memory Door: adım 2, 1 resimden 1.
      • Remove the three identical Phillips screws from the memory door.
      • Make sure to record which sets of screws came from where. This will help when re-assembling.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 15" Core Duo Model A1150 RAM Replacement: adım 3, 1 resimden 1.
      • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 15" Core Duo Model A1150 RAM Replacement, RAM: adım 4, 1 resimden 1.
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 15" Core Duo Model A1150 RAM Replacement: adım 5, 1 resimden 1.
      • Pull the chip directly out from its connector.
      • If there are two RAM chips installed, repeat the above procedure for the second chip.
      FixBot'a Sor
      Yorum Ekle
Sonuç
65 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 58
Her zaman: 63,719
