Giriş
Headphone jack on the fritz? Don't blast your tunes in the library, use this guide to restore headphone capability by replacing the headphone jack.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
Clockwise from top: keyboard, trackpad, battery, right speaker, keyboard backlight, display, microphone, headphone jack, left speaker.
Remove the two 3.6 mm T5 Torx screws securing the headphone jack to the upper case assembly.
Slide the headphone jack away from the upper case.
Lift and remove the headphone jack out from its recess in the upper case.
2 farklı kişi bu kılavuzu tamamladı.
2 Comments
Is the same applicable for Late 2013 version?
Thanks a lot anyway
Hi Maxim, unfortunately the headphone jack is soldered to the logic board in the late 2013 edition, you can check the late 2013 logic board replacement guide if you want to look at the cost of replacing the whole board, or if you are a skilled solderer!
