Giriş
Laptop take a tumble? Having trouble seeing through a jungle of cracks in your screen? Use this guide to replace your display assembly.
Neye ihtiyacın var
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Bu adımda kullanılan alet:Tweezers$4.99
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Use the flat end of a spudger to pry off the two rubber hinge covers, one from each end of the device.
139 farklı kişi bu kılavuzu tamamladı.
21Kılavuz Yorumları
I was a bit scared to do this... But it was actually not that hard... And I had no issues whatsoever. Thank you so much! You saved my ass hahaha.
Worked perfectly for me. Thanks for the guide!
Other iFixit guides worked great for me. So when my Macbook pro 15" retina late 2013 got a cracked display I bought a new one and tried assembling it with this guide. I tried this so many times, and even bought a couple of displays (both are supposed to have matched the model number of my laptop), but it didn't work for either of them. My old display, which was cracked, comes on, but the new ones I bought don't come on when I boot the computer. I've also tried those weird key combinations that they suggest for fixing a black screen elsewhere on the web. I am at my wit's end.
