Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Replace a faulty fan to keep temperatures down.
  1. Remove the following ten screws securing the lower case to the upper case:
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified. Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
    • Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
    • In some models, these T6 Torx screws may be 3.1 mm long.
  6. Use the flat end of a spudger to disconnect the left fan connector from the logic board. It is useful to twist the spudger axially from beneath the fan cable wires to release the connector. The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
    • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  7. Lift the left fan out of the upper case.
    • Lift the left fan out of the upper case.
Sonuç
60 farklı kişi bu kılavuzu tamamladı.
7 Yorum
IT is unclear as to which is the LEFT fan. Not having opened the case. It appears that the LEFT FAN is on the right as you look at the screen monitor. yes?
Karen Ratte - Yanıt
I agree that this has confused ma as well as I just ordered a right side fan from Amazon which matches the pictures of left side in this thread. Usually left and right should refer to the location of the laptop lid open and keyboard in working position - but that appears to be a wish only.
marbordom - Yanıt
I'd assume that the left fan is on the left side of the computer when you're using it. The pictures show that after the back plate is off, he's working on the right side of the computer. When I did this, i ordered the left fan, and when i flipped the computer over to replace it, the fan i ordered worked.
jrthom96 - Yanıt
Super facile, et quel silence ... enfin.
Goulven Bazire - Yanıt
I tore the connectors off the logic board when removing the fan connector. Wasted my time and money on the new fans. Hopefully machine will operate with only one fan since that’s all I have now.
rockportcentennial - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 59
Her zaman: 42,520
