Ana içeriğe geç
MacBook Pro 15" Unibody Early 2011 Lower Case Replacement
Neye ihtiyacın var
  1. MacBook Pro 15" Unibody Early 2011 Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Early 2011 Lower Case Replacement: adım 2, 1 resimden 1.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Sonuç
37 farklı kişi bu kılavuzu tamamladı.
2 Yorum
For re-assembly, tilt the screw driver slightly at an angle tangent to the case's edge when screwing in the seven 3 mm Phillips screws. Screw the 13 mm screws directly downward. This should ensure better thread engagement.
Matthew Adler - Yanıt
Another method for insuring screws end up on the right thread is to turn the screw in reverse (anti-clockwise) to begin with until you feel a click, then you'll know the screw has fallen into the thread correctly and you can drive it home clockwise.
John Ward - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 74
Her zaman: 28,879
