Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Replacing the MagSafe DC-In board requires removal of the logic board.
  1. Remove the following ten screws securing the lower case to the upper case:
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified. Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
    • Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
    • In some models, these T6 Torx screws may be 3.1 mm long.
  6. Use the flat end of a spudger to disconnect the left fan connector from the logic board. It is useful to twist the spudger axially from beneath the fan cable wires to release the connector. The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
    • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  7. Lift the left fan out of the upper case.
    • Lift the left fan out of the upper case.
  8. Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
    • Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
  9. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Kit Satın Al
    Enough RAM
    For All The Tabs
    Kit Satın Al
  10. Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board. Lift the right fan out of its opening in the logic board.
    • Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board.
    • Lift the right fan out of its opening in the logic board.
  11. Pull the camera cable out of its socket on the logic board.
    • Pull the camera cable out of its socket on the logic board.
    • Don't lift upward on the camera cable as you disconnect it. Pulling upward on the cable may damage both the cable and the logic board. Pull the cable parallel to the face of the logic board.
  12. Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
  13. Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
    • Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
  14. Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
    • Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
  15. Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
    • Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
    • Pry up from beneath the wires.
  16. Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board. Lift the cover off the logic board and set it aside.
    • Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board.
    • Lift the cover off the logic board and set it aside.
  17. Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
    • Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
  18. Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
  19. Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
    • Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
  20. Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer. Pull the display data cable straight out of its socket on the logic board.
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  21. Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket. Be sure you are flipping up the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Be sure you are flipping up the hinged retaining flap, not the socket itself.
    • Pull the keyboard backlight ribbon cable out of its socket.
  22. Remove the following nine screws:
    • Remove the following nine screws:
    • Seven 3.4 mm ( 3.1 mm) T6 Torx screws on the logic board
    • Two 8 mm T6 Torx screws on the DC-In board
  23. Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal. If necessary, use the flat end of a spudger to separate the microphone from the upper case. Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
    • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
    • If necessary, use the flat end of a spudger to separate the microphone from the upper case.
    • Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
  24. Disconnect the DC-In board by pulling its cable toward the heat sink.
    • Disconnect the DC-In board by pulling its cable toward the heat sink.
    • Pull the cable parallel to the face of the logic board.
Sonuç
54 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Connecting the keyboard was very difficult, the key to do it is to pull out the lock. Thanks for the guide :)
PJBG - Yanıt
Hello , my Mac book pro. 2011 has been shut down by itself after a spark in charger what could be the problem it is please explain it.
Sam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 114
Her zaman: 25,728
