Ana içeriğe geç
MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement
Neye ihtiyacın var
  1. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement, Lower Case: adım 1, 1 resimden 1.
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 2, 1 resimden 1.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement, Battery Connector: adım 3, 2 resimden 1. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement, Battery Connector: adım 3, 2 resimden 2.
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 4, 1 resimden 1.
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Remove two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  6. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 6, 1 resimden 1.
    • Lift the retaining bracket out of the upper case.
  7. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 7, 1 resimden 1.
    • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
  8. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 8, 2 resimden 1. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 8, 2 resimden 2.
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
  9. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement, Hard Drive/IR Sensor Cable: adım 9, 1 resimden 1.
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
  10. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 10, 1 resimden 1.
    • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
    • Two 1.5 mm Phillips screws.
    • Two 4 mm Phillips screws.
  11. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 11, 3 resimden 1. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 11, 3 resimden 2. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 11, 3 resimden 3.
    • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
    • Carefully peel the hard drive and IR sensor cable from the upper case.
    • Lift the hard drive and IR sensor assembly out of the upper case.
  12. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 12, 3 resimden 1. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 12, 3 resimden 2. MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement: adım 12, 3 resimden 3.
    • Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable.
    • Use the tip of a spudger to flip the ZIF connector on the hard drive cable.
    • Gently pull the sensor bracket cable out of the ZIF connector.
    • Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket.
    • Remove the adhesive backing from your new hard drive cable, stick it onto the sensor bracket, and connect the sensor bracket cable.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Great instructions - I am not an expert, and was able to change the hard drive cable in 25 minutes without issues. Thanks!
lerfamu - Yanıt
Followed these instructions and completed the changeover, probably took half hour. The final step with the ZIF connector I was unable to see exactly how it worked but managed with a bit of trial and error and things are now working. Perhaps a closer photo or perhaps a diagram as to how the connector works? But all in all things worked. Thanks
martin riley - Yanıt
Is there any way to fix failed graphics card on MacBook Pro 2011. At this stage it’s looking like I have to trash the thing?
Victor holmes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 36
Son 30 gün: 185
Her zaman: 11,537
