Giriş
Use this guide to replace a burned-out right fan.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
24 farklı kişi bu kılavuzu tamamladı.
