Giriş
Replacing the upper case requires removal of nearly every component inside your MacBook Pro.
Parçalar
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
If necessary, use the flat end of a spudger to separate the microphone from the upper case.
Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
Remove the two 7.5 mm ( 7.2 mm )Tri-point screws securing the battery to the upper case.
Remove the following six screws securing the subwoofer and right speaker to the upper case:
Two 3.2 mm ( 3.0 mm ) Phillips screws.
Two 12.3 mm Phillips screws.
One 2.5 mm Phillips screw.
One 8.3 mm ( 8.1 mm ) Phillips screw.
Lift the subwoofer and right speaker assembly out of the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
34 farklı kişi bu kılavuzu tamamladı.
