Giriş
Remove the lower case to access most of your MacBook Pro's internals.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
46 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
When replacing the lower case, be sure to re-seat the clips that popped when removing it. There are two, located near the edge of the battery and the motherboard. Apply firm pressure over these spots until the clips click again, before replacing the screws.
