Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
MacBook Pro 15" Unibody Mid 2010 RAM Replacement
Neye ihtiyacın var
  1. MacBook Pro 15" Unibody Mid 2010 RAM Replacement, Lower Case: adım 1, 1 resimden 1.
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 RAM Replacement: adım 2, 1 resimden 1.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2010 RAM Replacement, RAM: adım 3, 3 resimden 1. MacBook Pro 15" Unibody Mid 2010 RAM Replacement, RAM: adım 3, 3 resimden 2. MacBook Pro 15" Unibody Mid 2010 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Sonuç
227 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Step 3
Could not get ram to lock in correctly. Verified twice that it was the correct part but when installed i get a beeping sound on reboot and nothing else. Any suggestions?
Mark Nunes - Yanıt
Has ANYONE decided to hotrod the ram by upgrading it to 16gig? It says not to do it but doesn't say WHY. And with mine already running an SSD. I want to hot rod this baby as much as possible. I don't mind the 8gig that it has now but I do video work and could use the extra 8gig's.
Jeffrey Collins - Yanıt
According to this, the CPUs in the Mid2010 MBP only support up to 8 GB
2.66 Ghz i7: http://ark.intel.com/products/43560/Inte...
2.53 Ghz i5: http://ark.intel.com/products/43544/Inte...
casthle -
@Jeffrey no you cant hotrod those macbooks, the only one that can be hotrod in macbook pro range is the mid 2010 13in 2,4ghz duo core which is what i have and 2 minutes ago i have successfully upgraded to 16gb with no problems, yet to try out performance but it will be much better than the 4gbs i had previously.
Tye Nguyen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 31
Son 30 gün: 104
Her zaman: 147,227
