Giriş
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Remove three T6 Torx screws securing the right fan to the logic board and upper case.
58 farklı kişi bu kılavuzu tamamladı.
