Ana içeriğe geç
MacBook Pro 16" 2019 Speaker Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. MacBook Pro 16" 2019 Speaker Replacement, Open the Macbook: adım 1, 2 resimden 1. MacBook Pro 16" 2019 Speaker Replacement, Open the Macbook: adım 1, 2 resimden 2.
    • First step is opening up the MacBook. This was the most challenging step and maybe because it got me by surprise. The process works a bit different then older MacBooks. Watch this video if you are not aware of the process: https://www.youtube.com/watch?v=mHutSzIk...
    • Hint - Try pulling the bottom cover forward.
  2. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: adım 2, 3 resimden 1. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: adım 2, 3 resimden 2. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: adım 2, 3 resimden 3.
    • After opening up, disconnect the battery. Remove the cable and take out the big screw; this is to make sure there is no power running through.
  3. MacBook Pro 16" 2019 Speaker Replacement, The part: adım 3, 2 resimden 1. MacBook Pro 16" 2019 Speaker Replacement, The part: adım 3, 2 resimden 2.
    • I'm going to replace the left and right speaker. I bought a few on AliExpress, since they were sold out on iFixit, however they arrived damaged. Hopefully they work.
  4. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the speaker: adım 4, 2 resimden 1. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the speaker: adım 4, 2 resimden 2.
    • On both sides, open up the connector and take out the cable.
  5. MacBook Pro 16" 2019 Speaker Replacement, Remove the Speaker: adım 5, 2 resimden 1. MacBook Pro 16" 2019 Speaker Replacement, Remove the Speaker: adım 5, 2 resimden 2.
    • Taking out the speaker is where it gets sketchy. It's hanging in there with VERY strong adhesive. Luckily, I'm going to replace the speakers and am not going to keep them so I can be rough. If you want to keep the speaker, I would advise another approach.
  6. MacBook Pro 16" 2019 Speaker Replacement, Take out the other side: adım 6, 2 resimden 1. MacBook Pro 16" 2019 Speaker Replacement, Take out the other side: adım 6, 2 resimden 2.
    • Same story on the other side. Wiggle your tool underneath and force it out.
  7. MacBook Pro 16" 2019 Speaker Replacement, Remove the adhesive: adım 7, 2 resimden 1. MacBook Pro 16" 2019 Speaker Replacement, Remove the adhesive: adım 7, 2 resimden 2.
    • Removing the adhesive and pulling it out is easy. If you can't pull it out, use a tool to carefully scratch it off the surface.
  8. MacBook Pro 16" 2019 Speaker Replacement, Clean the adhesive: adım 8, 1 resimden 1.
    • When cleaning the leftover adhesive, it's best to use an alcohol pad to clean it up as well as the general area.
    • Let the area dry before installing the speaker.
  9. MacBook Pro 16" 2019 Speaker Replacement, Ready for replacing: adım 9, 1 resimden 1.
    • After removing both speakers, your MacBook should look like the one in the photo.
    • If you cleaned off adhesive in the previous step, make sure the area is clean/dry before moving on.
  10. MacBook Pro 16" 2019 Speaker Replacement, Glue: adım 10, 1 resimden 1.
    • This step is optional if your replacement speaker does not have any adhesive.
    • Put adhesive around the outside of the speaker; use the glue sparingly.
    • Make sure you are using a glue that is specifically designed for computer repair or speaker repair. Here is a solvent that can be used for this guide.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Dave Hakkens
1.042 İtibar
3 adet Kılavuz yazıldı
11Kılavuz Yorumları
I just created an account to thank you,
I bought the speakers from ifix it, and I did follow your guide, and it worked perfectly.
so I joined here to thank you.
your guide helped me a lot. I appreciate the effort.
ALAA ALMAATOUQ - Yanıt
appreciate that. Happy to hear its useful :)
Dave Hakkens -
This was very helpful... I managed to successfully replace mine... but unfortunately on step 5 I made the mistake of scuffing the battery, revealing the aluminum layer inside and it gave off a sweet smell (which i now understand is dangerous)
Painfully had to have the battery replaced for about 300$ (I'm in Nairobi, Kenya)
Maybe update the steps to avoid the nearby battery which is really sensitive.
Cheers
leemalu - Yanıt
Thank you for this! I broke my speaker when following a different iFixIt guide, but your instructions saved the day. $49 is even for the replacement speaker from iFixIt is even cheaper than the deductible on my insurance plan through GetAkko, so this one was a no-brainer. Thank you, internet stranger!
Peter - Yanıt
What are the tools that I’ll need to do this? Are they available on iFixit? Thank you!
[deleted] - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 161
Son 30 gün: 708
Her zaman: 20,538
