Giriş
Install an AirPort Extreme 802.11g card internally.
Parçalar
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the two antenna cables attached to the AirPort Extreme card.
3 farklı kişi bu kılavuzu tamamladı.
