Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Backlight not working? Use this guide to replace a burned out display inverter.
Neye ihtiyacın var
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the two antenna cables from the AirPort Extreme card, the iSight and inverter cables from the left side of the logic board, and the display data cable from the right side of the logic board. Be careful to slide the connectors as they may become damaged otherwise.
Carefully peel the iSight and inverter cables off the top of the left fan and de-route the AirPort antenna cables from the channel in the left speaker.
Remove the Phillips screws from the lower left and right corners of the display (two screws total).
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Insert the flat end of a spudger into the gap between the rear display bezel and the clutch cover.
Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
Work along the lower edge of the rear bezel until it is evenly separated from the clutch cover.
Remove the piece of tape securing the backlight cables to the front display bezel.
13 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Fantastic thankyou very very much great step throughs.
I'm interested in getting the inverter for this mac computer, since I'm hurting the MacBook Pro 17 inverter "Models A1151 Display Inverter Replacement
