Ana içeriğe geç
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement
Neye ihtiyacın var
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Battery: adım 1, 1 resimden 1.
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
    Before upgrading to a larger HD, you'll want to "clone" your original HD using the donation-ware program "Carbon Copy Cloner" (http://www.bombich.com/). Put the new HD in an external case; clone the original; test the clone (by starting up with it), then take apart the MacBook to put the new HD in the MacBook, and the original in the external case for use as a backup, etc. (You can't just drag the contents of the original HD to the new HD, and expect it to work; not since the days of OS 9 and before.)
    amiller770 - Yanıt
    Can I put more than two gigabytes of RAM in?
    Noah Nsangou - Yanıt
    mine has 2g*2=4 gb ram in. you should be fine
    on mac forum it suggested to put 4gb and a 2gb in a1261.
    david -
    I made the mistake of wanting to do a clean install of OS and start fresh after installing a SSD. Now I can't install most browsers on OSX Leopard. Does anyone know what is the most current version of OS I can put on this system? (disk or download) Can I get to Snow or Lion?
    2006 17" MackBook Pro Model#A1151
    2.16 GHz Intel Core Duo
    Memory: Two 1GB 667 MHz
    Hard Drive: Corsair Force GS: SSD 128GB
    scannon - Yanıt
    You can install OS X 10.7 LION and no later version. Although LION runs ok with 2GB RAM it does help to get 1GB + 2GB = 3GB. Even if you install 2 X 4GB you will only utilize 3GB. Installing a SSD seems to make no difference since the SATA bus is only 1.5GB/s. A good 5400rpm disk is good enough. I even run BootCamp and Windows 7. Works fine. Not fast but fine. My A1212 refuses to die :-)
    asle -
    There seems to be some discrepancy about whether or not installing a SSD will help. See Phil's earlier comment from October 2015: there, *he* claims that having an SSD increases the load times significantly, (even though -- of course -- 1.5Gbps is not ideal)...
    His quotation, (re-)cited integrally:
    Just replaced my old HD with a Corsair Force LX SSD (which is SATA 1-3 compatible as required by this model) with success now my old 'outdated' laptop has super fast loading times and is postively flying faster than the speed of 'sound'. Thanks for the guide. Only problem I faced was replacing the top panel which after a few minutes of panic realised the rubber mounted Mic next to the left speaker had risen up when I had removed the top panel so after carefully pushing it back into place the panel fitted back how it should, so beware of this possible problem.
    Phil - 10/07/2015
    at0gjm -
    Bonjour j'ai besoin de cette bactérie que dois-je faire ?
    basile kouamé YAO - Yanıt
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, RAM Shield: adım 2, 1 resimden 1.
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 3, 1 resimden 1.
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Upper Case: adım 4, 1 resimden 1.
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
    One of the screws here wouldn't bite going back in. I'm 100% certain it's the same screw that came out of it but it wouldn't bite going back, neither would any of the other two in this section in that particular hole.
    Damon B - Yanıt
    To Damon - possibly the thread on the bottom of the upper case is obstructed.
    I found that I needed to fight the latch magnet with the right-most screw in the photo. The screw was pulled away from the hole so a magnetized screwdriver was not enough to place it. I needed tweezers to hold the screw in place until it bit.
    Yishai Sered - Yanıt
    No, these screws won’t bite going back in — struggled for an hour. Lost hope of success.
    Case screw holes perfectly lined-up, neatly closed body, screw threads/head are fine (Apple quality screws), perfect screwdriver.
    The left one is in, other two simply will not bite whatsoever. Slightly irritating eventually turned to madly infuriating. I have a similar, earlier model and that was smooth to replace these exact, slightly angled screws (so I have experience).
    Q: Are the centre and right-hand screws absolutely essential — or can I give up and leave them out?
    (By the time you read this, that’s what I’ll have done)(out of sheer frustration)
    Steve Arkwright - Yanıt
  5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 5, 1 resimden 1.
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
    Note for re-assembly: For the hinge use the longest four Phillips screws.
    R L - Yanıt
    The Philips screws in Step 5 are longer than the other Philips screws. Would be better if the instructions differentiated them. Otherwise it is possible to use the wrong screws in Step 7 when reassembling.
    Alex - Yanıt
    These instructions are actually wrong. The 14.5 mm screws are for along the hinge, the 2 on either side of the RAM slot are about 10 mm.
    Andrew Patterson - Yanıt
  6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 6, 1 resimden 1.
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
    When reassembling, please be careful not to screw into the wrong spot. I accidentally screwed into the DVI port and it was hard to remove the screw after that. I had to disassemble the whole thing again, only to find that I couldn't remove the screw from within as it was encased. After much scraping and prodding with a sewing needle, I was able to get that screw out. Phew!
    isotope434 - Yanıt
  7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 7, 1 resimden 1.
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
    Screw on the right is shorter
    mikefal - Yanıt
    What are these two screws called?
    ian - Yanıt
  8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 8, 1 resimden 1.
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 9, 1 resimden 1.
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
    WOW this step is very hard!!! its a serious suction cup..
    nya - Yanıt
    Once the upper case is free...Carefully tilt the upper case from the front towards the screen as their is a ribbon cable directly beneath the keyboard and trackpad that will need to be removed in the next step.
    Troy - Yanıt
    Be very careful not to bend the screw tabs on the top case the perimeter screws attach to. Bending them causes them to quickly fatigue and potentially break off. When reassembling the top case, be sure the tabs are all *inside* the case before reseating it. If you get resistance, pull the case back up, check the tabs and reseat the top case again.
    Sheldon Carpenter - Yanıt
  10. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 10, 1 resimden 1.
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
    Disconnecting this cable is optional, if instead you tip up the top case ~75 degrees, propping it up with something non-metalic (wedged in or by the battery compartment). Unplugging a connector from the main circuit board always carries slight additional risk.
    amiller770 - Yanıt
    It's not really necessary to disconnect the trackboard/keyboard ribbon cable. You can simply lean the upper case against the LCD.
    Russ Greene - Yanıt
    how reconnect this cable?
    anatole - Yanıt
    I did this with and without step 10 (removing the upper case with detached cable). Removing the cable is risk, putting it back on was not so easy. But then, leaning the keyboard part against the LCD while replacing the hard drive is also risky.
    tobybaier - Yanıt
    After having successfully removed/reattached the ribbon cable several times while trying to revive this computer for back-up use the securing/release tabs on the connector broke. The connector then will not hold the cable properly and connecting fails. Tried various methods of propping the cable in the connector to get full contact but eventually all efforts failed, too. Result: essentially a dead motherboard as no replacement for the connector seems available. Sadly, not worth the extra effort to try further repairs.
    Steve colton - Yanıt
  11. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Display: adım 11, 3 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Display: adım 11, 3 resimden 2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Display: adım 11, 3 resimden 3.
    • Disconnect the two antenna cables from the AirPort Extreme card, the iSight and inverter cables from the left side of the logic board, and the display data cable from the right side of the logic board. Be careful to slide the connectors as they may become damaged otherwise.
    • For A1229 and A1212 models, disconnect the three antenna cables from the AirPort Extreme card and the three connectors highlighted on the logic board.
    • For the A1229, the order of the cables from left to right is: Black (left; towards the edge of the case) — Grey (middle) — Blue (right; towards the middle of the case.
    • For the A1261 model, disconnect the two antenna cables from the AirPort Extreme card and the three connectors highlighted on the logic board.
    • Carefully peel the iSight and inverter cables off the top of the left fan and de-route the AirPort antenna cables from the channel in the left speaker.
    Remember to replace the little sponge-type object on top of the right-side set of 3 screws, towards the right.
    Andrew - Yanıt
    anybody got any advice re: how to detach the connector on that tiny little ribbon, the one on the upper left with the larger ribbon/connector alongside it? I tried and tried... gave up for fear of damaging the wires, plus concern about how difficult it might be to get it back in. Thx in adv
    firenzeitalia - Yanıt
    Firenzeitalia: The tiny little black one is the scariest part of the whole job. You need to use a firm spudger to slide it out to the left. Possibly even use the pointy end, but it slides out quite easily.
    The hard part is getting it to slide back in again later — especially if you have large fingers. Essentially, you’re going to have to do it blind — and by ‘feel’ — because you can’t see what you’re doing.
    Fortunately, Apple made it so that the black housing lines-up to the sides and the four tiny receptor prongs: once you’ve slid it into place and it looks correctly in, you then push down on it — to snap it in properly.
    This is the time to re-attach the keyboard (put a cloth over the screen), plug in power and turn the machine on to test you’ve done it right.
    If you’ve attached the tiny Inverter housing correctly, the screen will light up and boot as expected. If the screen remains black, remove the keyboard and cable again — gently — and check the Inverter and Display Data Cable are correctly inserted.
  12. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 12, 1 resimden 1.
    • Remove the ten silver T6 Torx screws securing the display (five on each side-take note that the inside screws on both sides are longer with a thinner head).
    • Don't forget to replace the hinge end caps when reinstalling the display assembly. The end caps are side specific, so be sure that the posts are facing towards the lower case.
    To clarify the placement of the different screws:
    There are two sets of 2 on each side and two sets of 3 on the insides. The "long" screws with "flat" heads are meant for the INSIDE of the sets of 3. I will represent short screws by the letter "S" and the long screws by the letter "L":
    S S - S S L - L S S - S S
    Andrew - Yanıt
    But what are the measurements of the screws? Its T6 but how many millimeters long is the screw?
    Sean Love -
    The longer two (middle) screws are about 14mm and the rest (identical) are approximately 10mm.
  13. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 13, 1 resimden 1.
    • Grasp the display assembly on both sides and lift it up and out of the computer.
    If you came to the Display Removal guide to replace just the LCD panel and not the entire assembly, you need to head over to the Front Bezel replacement guide.
  14. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Rear Display Bezel: adım 14, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Rear Display Bezel: adım 14, 2 resimden 2.
    • The hinge end caps on this model can be easily removed at this point, as they are not fastened to the hinge and may fall off during service.
    • Remove the Phillips screws from the lower left and right corners of the display (two screws total).
    Couldn't get the screws back on the rear bezel but might just be a problem with my rear bezel as the two sockets where I think the screws screw into fell out.
    Rocio - Yanıt
  15. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 15, 3 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 15, 3 resimden 2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 15, 3 resimden 3.
    • Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
    • Do not insert your spudger between the plastic strip and the rear bezel.
    • With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
    • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
  16. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 16, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 16, 2 resimden 2.
    • Insert your spudger between the front and rear display bezels at the lower right corner of the display.
    • Pry the rear bezel away from the front bezel to slightly separate the bottom edge of the rear display bezel.
  17. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 17, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 17, 2 resimden 2.
    • Insert the flat end of a spudger into the gap between the rear display bezel and the clutch cover.
    • Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
    • Work along the lower edge of the rear bezel until it is evenly separated from the clutch cover.
  18. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 18, 3 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 18, 3 resimden 2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 18, 3 resimden 3.
    • Now that the right and bottom edges of the rear bezel are slightly separated from the front bezel, use a spudger to pop the rear bezel off the tabs near the lower right corner of the display.
    Prying the rear display bezel off up with the plastic spudger can be frustrating. The plastic spudger just can't provide the torque. I actually used the combination of the plastic spudger (to start the separation) and a metal spudger to provide sufficient force to separate. I wrapped the metal spudger with some tape to prevent scratching. As usual, care is required to not bend the front bezel.
  19. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 19, 3 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 19, 3 resimden 2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 19, 3 resimden 3.
    • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
    • Rotate your spudger toward the rear bezel to separate it from the front bezel.
    • If necessary, continue separating the left edge of the rear bezel off the tabs on the front display bezel.
  20. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 20, 1 resimden 1.
    • Slightly lift the lower edge of the display and pull it away from the rear display bezel.
    • The rear display bezel remains.
  21. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Display Inverter: adım 21, 1 resimden 1.
    • Remove the piece of tape securing the backlight cables to the front display bezel.
  22. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 22, 3 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 22, 3 resimden 2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 22, 3 resimden 3.
    • Carefully lift the inverter out of the clutch cover.
  23. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 23, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 23, 2 resimden 2.
    • Disconnect the inverter cable by pulling its connector away from the socket on the inverter board.
    During my LCD replacement, I did not do this, nor remove the inverter board, I just unplugged the cord in step 24 and left the inverter board in the clutch cover assembly.
  24. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 24, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 24, 2 resimden 2.
    • Disconnect the backlight connector from the inverter board.
    • Be careful when removing this connector, as it may be firmly seated in its socket.
    • Remove the inverter from the display.
  25. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Clutch Assembly: adım 25, 1 resimden 1.
    • Use the flat end of a spudger to carefully peel off the three antenna straps stuck to the lower edge of the LCD.
    Be careful pulling off the kapton tape. Because of the age of the computer and the continuous heating and cooling, the tape can become brittle and the adhesive will stick to the surface of the LCD and not the tape itself, making it unusable. If this happens, you can find small rolls of kapton tape on the internet or get it in the ifixit store.
  26. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 26, 1 resimden 1.
    • Remove the five Phillips screws securing the clutch cover to the bottom edge of the front display bezel.
    If you are replacing the LCD and not the front bezel, you really don't need to remove the clutch cover and clutch hinges. You have full access to the LCD screws and can remove it, skipping this step, as well as the steps 29, 30, 31, 32, 37 and 39. The clutch cover, inverter board and all cables will remain attached to the front bezel.
    Especially since these computers are old now, these screws are easy to strip down. Make sure you don't screw them in too tightly, as you may not be able to take it back out. The middle of the 5 I had to leave abandoned. Thankfully, it didn't impede my repair.
    Andrew - Yanıt
    The cables didn't fit right when I put the clutch onto the front bezel so I tried to disassemble but the middle screw is stuck. The tiny little cable that's connected to this screw ripped :( If I do manage to get the screw out, not sure if I have to replace this whole cable even though it's just a small side cable connected to the inverter cable I think.
    Rocio - Yanıt
    Finally got the screw out, and put the cables in the clutch assembly correctly. Works despite the isight/inverter cable's tiny second thread having been torn.
    Take photos of what this looks like bc you have to make sure the cables fit in the clutch and are long enough to fit in the motherboard properly.
    Rocio - Yanıt
  27. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 27, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 27, 2 resimden 2.
    • Remove the two pieces of tape securing the display data cable to the LCD.
  28. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 28, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 28, 2 resimden 2.
    • Disconnect the display data cable from the LCD by pulling it toward the bottom edge of the display.
  29. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 29, 1 resimden 1.
    • Move the display data cable out of the way to remove the Phillips screw hidden underneath.
  30. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 30, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 30, 2 resimden 2.
    • While pulling the clutch assembly away from the clutch hinge with one hand, insert an iPod opening tool between the clutch cover and the front display bezel to lift the clutch cover over the retaining pin on the front display bezel.
    • Pull the clutch assembly away from the front display bezel.
    Before you completely detach the clutch assembly, take note of how everything is organized inside it, as you will be replicating it upon reassembly. The display data cable ended up being in the way as I was closing everything up and had to reopen everything to readjust it. Take pictures and see how it will fit into place before you reattach the clutch assembly and screw in the 5 screws.
    Andrew - Yanıt
    Took me a long time to get the clutch out, it felt stuck, but after 20 minutes I finally managed.
    Rocio - Yanıt
  31. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 31, 1 resimden 1.
    • Repeat the process covered in the previous step to free the other side of the clutch assembly from the front display bezel.
  32. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 32, 1 resimden 1.
    • Remove the clutch assembly from the front display bezel, minding any cables that may get caught.
    The pins may be hard to notice, but they are both emanating from the bezel as simple pins in sockets. The motion you are looking for to detach the clutch assembly is slightly outward towards you, and then sliding down.
    Andrew - Yanıt
  33. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Inverter/Antenna Cables: adım 33, 1 resimden 1.
    • Remove the three pieces of tape securing the camera cable to the display assembly.
  34. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 34, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 34, 2 resimden 2.
    • Use the tip of a spudger or your fingernail to flip up the ZIF retaining flap on the camera cable socket at the edge of the camera board near the top center of the front display bezel.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the camera cable out of its socket.
  35. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 35, 1 resimden 1.
    • Peel the camera cable off the foam tape along the top edge of the display.
  36. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 36, 1 resimden 1.
    • Remove the inverter/antenna cables from the display.
  37. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Left Clutch Hinge: adım 37, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Left Clutch Hinge: adım 37, 2 resimden 2.
    • Remove the four 3.5 mm T6 Torx screws securing the left clutch hinge to the front display bezel.
    • Remove the left clutch hinge from the front display bezel.
  38. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement, Front Display Bezel: adım 38, 1 resimden 1.
    • Remove the display data cable from the display.
  39. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 39, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 39, 2 resimden 2.
    • Remove the four 3.5 mm T6 Torx screws securing the right clutch hinge to the front display bezel.
    • Remove the right clutch hinge from the front display bezel.
  40. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 40, 1 resimden 1.
    • Remove the four 3.2 mm Phillips screws along the right edge of the display.
  41. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 41, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 41, 2 resimden 2.
    • Remove the two 3.2 mm Phillips screws on the top edge of the display.
  42. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 42, 1 resimden 1.
    • Remove the four 3.2 mm Phillips screws along the left edge of the display.
  43. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 43, 1 resimden 1.
    • The next few steps will require you to separate the LCD from the adhesive applied to the upper and lower edges of the front bezel.
    • The adhesive is applied such that it sticks to a thin steel strip around the perimeter of the LCD. When prying your LCD away from the front panel, be sure you are separating the front panel from the steel strip on the LCD.
    • Use the flat end of a spudger to gently lift one of the top corners of the LCD out of the front bezel.
    This can be a difficult step if not done carefully, resulting in bending or even breaking the front bezel. I gently heated the top and bottom front of the bezel with a hair dryer, which made LCD easier to pry away from the front bezel.
  44. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 44, 1 resimden 1.
    • Work your way along the top edge of the LCD, slowly prying the attached steel strip away from the front bezel.
    • Continue prying the LCD off the front bezel along the left side of the display.
  45. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 45, 1 resimden 1.
    • Now that the top and left edges are free, slightly lift the LCD out of the front bezel for enough room to pry the steel strip along the lower edge of the LCD away from the front bezel.
    • Pry along the lower edge of the LCD until it is freed from the adhesive on the front bezel.
    If you plan on reusing this bezel, inspect it carefully for any bends. Gently straighten it before attaching the new LCD to the bezel.
  46. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 46, 2 resimden 1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Front Display Bezel Replacement: adım 46, 2 resimden 2.
    • Lift the LCD out of the front bezel, minding any cables that may get caught.
    • Replacement Note: there are clear plastic spacers attached via adhesive to the sides and bottom of the lcd panel. Be sure to transfer these spacers to the replacement panel for optimum fit.
    • Front bezel remains.
    When reassembling your LCD to your old bezel, be sure to press the new bezel firmly back to the old adhesive to attach it.
    Successfully replaced this. Ended up having to replace the front bezel, the clutch assembly, and the top case. Took about 15-16 hours over 3 days to do it all.
    Rocio - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Are the bezels on the A1151 A1212 A1229 and A1261 all interchangeable? (can the front bezel from any of those models go on my a1229?)
thomas cares - Yanıt
They are very similar but a search on the internet shows three different part numbers.
Sheldon Carpenter -
Seriously consider using a screw sorter when doing this guide. I actually use a fishing tackle organizer. They have lids you can close, thus preventing any accidental screw spillage. I actually use two sorters, one for the case screws, and one for whatever parts inside I am repairing.
Thanks, my MacBook Pro is now getting full use once more. This guide was very helpful. It was a smooth process.
Jon Martinez - Yanıt
Check out a time lapse of this whole process.
http://youtu.be/J-9jUiLoRcQ
d a w j a - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 21,405
