Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The left thermal sensor for Models A1151 and A1212 is the middle thermal sensor for the A1229. Use this guide to replace the middle thermal sensor on a MacBook Pro 17" Model A1229.
This detects the internal temperature of your machine for heat management.
Neye ihtiyacın var
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
If the right speaker assembly remains attached to the logic board, hold the logic board with one hand and slide the speaker up slightly to free it from the logic board.
To properly reassemble your MacBook Pro, you'll have to clean off and replace the thermal compound from the three chips on the underside of the logic board. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
Peel up the orange Kapton tape covering the left thermal sensor.
Use a spudger to pry the left thermal sensor off from the heat sink.
Bir başkası bu kılavuzu tamamladı.
