Giriş
Two RAM slots allow up to 2 GB of PC2-5300 RAM.
Neye ihtiyacın var
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
113 farklı kişi bu kılavuzu tamamladı.
2 Yorum
My 1261 came w/2 of the 2gig sticks and If I understand things I'read here, I buy a 4 gig stick and replace one of the already installed 2 gig sticks and the machine will see and use 6. Is this about it?
Jim in Chicago
Yes Jim, that is it.
Before upgrading to a larger HD, you'll want to "clone" your original HD using the donation-ware program "Carbon Copy Cloner" (http://www.bombich.com/). Put the new HD in an external case; clone the original; test the clone (by starting up with it), then take apart the MacBook to put the new HD in the MacBook, and the original in the external case for use as a backup, etc. (You can't just drag the contents of the original HD to the new HD, and expect it to work; not since the days of OS 9 and before.)
amiller770 - Yanıt
Can I put more than two gigabytes of RAM in?
Noah Nsangou - Yanıt
mine has 2g*2=4 gb ram in. you should be fine
on mac forum it suggested to put 4gb and a 2gb in a1261.
david -
I made the mistake of wanting to do a clean install of OS and start fresh after installing a SSD. Now I can't install most browsers on OSX Leopard. Does anyone know what is the most current version of OS I can put on this system? (disk or download) Can I get to Snow or Lion?
2006 17" MackBook Pro Model#A1151
2.16 GHz Intel Core Duo
Memory: Two 1GB 667 MHz
Hard Drive: Corsair Force GS: SSD 128GB
scannon - Yanıt
You can install OS X 10.7 LION and no later version. Although LION runs ok with 2GB RAM it does help to get 1GB + 2GB = 3GB. Even if you install 2 X 4GB you will only utilize 3GB. Installing a SSD seems to make no difference since the SATA bus is only 1.5GB/s. A good 5400rpm disk is good enough. I even run BootCamp and Windows 7. Works fine. Not fast but fine. My A1212 refuses to die :-)
asle -
There seems to be some discrepancy about whether or not installing a SSD will help. See Phil's earlier comment from October 2015: there, *he* claims that having an SSD increases the load times significantly, (even though -- of course -- 1.5Gbps is not ideal)...
His quotation, (re-)cited integrally:
Just replaced my old HD with a Corsair Force LX SSD (which is SATA 1-3 compatible as required by this model) with success now my old 'outdated' laptop has super fast loading times and is postively flying faster than the speed of 'sound'. Thanks for the guide. Only problem I faced was replacing the top panel which after a few minutes of panic realised the rubber mounted Mic next to the left speaker had risen up when I had removed the top panel so after carefully pushing it back into place the panel fitted back how it should, so beware of this possible problem.
Phil - 10/07/2015
at0gjm -
Bonjour j'ai besoin de cette bactérie que dois-je faire ?
basile kouamé YAO - Yanıt
