Ana içeriğe geç
MacBook Pro 17" Unibody fixing noise fan and overheat
Neye ihtiyacın var
  1. MacBook Pro 17" Unibody  fixing noise fan and overheat, Before starting: adım 1, 1 resimden 1.
    • I am using Husky screwdrivers HD 74501 U & HD 74502 Y
  2. MacBook Pro 17" Unibody  fixing noise fan and overheat, Getting ready: adım 2, 1 resimden 1.
    • Turn your MBP upside down
  3. MacBook Pro 17" Unibody  fixing noise fan and overheat, Screws first: adım 3, 1 resimden 1.
    • Remove the screws from the back cover
  4. MacBook Pro 17" Unibody  fixing noise fan and overheat, Open it !: adım 4, 1 resimden 1.
    • Carefully open the back cover.
  5. MacBook Pro 17" Unibody  fixing noise fan and overheat, Dust ? No, thanks !: adım 5, 1 resimden 1.
    • Remove the dust . I am using a vacuum cleaner here with a brush.
  6. MacBook Pro 17" Unibody  fixing noise fan and overheat, Apple warranty: adım 6, 1 resimden 1.
    • Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
    • Keep your Apple warranty and disconnect the battery.
  7. MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: adım 7, 3 resimden 1. MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: adım 7, 3 resimden 2. MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: adım 7, 3 resimden 3.
    • Disconnect the fan from the mainboard.
  8. MacBook Pro 17" Unibody  fixing noise fan and overheat, Almost there !: adım 8, 1 resimden 1.
    • Remove the 3 screws that fron the fan fixture.
  9. MacBook Pro 17" Unibody  fixing noise fan and overheat, Take a walk on the wild side !: adım 9, 1 resimden 1.
    • Clean the dust with a very soft toilet paper.
  10. MacBook Pro 17" Unibody  fixing noise fan and overheat, Finally!: adım 10, 1 resimden 1.
    • This is what I´ve found inside one fan !
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
LAOMUSIC ARTS
613 İtibar
1 Kılavuz yazıldı
6Kılavuz Yorumları
I’d be careful about using a vacuum cleaner on the inside of the computer as it can cause static discharge and zap your components.
pov - Yanıt
Thanks a lot s
Sanzi Gao - Yanıt
Sanzi Gao - you are welcome!
LAOMUSIC ARTS - Yanıt
@laomusicarts do you know where I might be able to get an HD-74501 screwdriver. New or Used?
Kendall Lui - Yanıt
Since my 2008 Macbook Pro has been overheating for a while I tried this. Unfortunately everything inside is quite clean: no dust in the fans or heat-sinks.
The fans run quite well , and get going pretty fast as the device heats up. Any other ideas are welcome, This was a GREAT machine and I miss using it.
Eric Hammond - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 10,018
