Giriş
Use this guide to replace your Bluetooth board.
Neye ihtiyacın var
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
6 farklı kişi bu kılavuzu tamamladı.
