Giriş
Maybe it's cracked. Maybe it's old. Either way, a nasty looking clutch cover is not good. Use this guide to replace the clutch/hinge cover.
Neye ihtiyacın var
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
Grab the clutch cover as shown and slide it toward the right side of the display.
9 farklı kişi bu kılavuzu tamamladı.
