Giriş
Use this guide to replace the hard drive bracket nearest the front edge of the MacBook Pro 17" Unibody.
Neye ihtiyacın var
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
10 farklı kişi bu kılavuzu tamamladı.
