Ana içeriğe geç
MacBook Pro 17" Unibody Hard Drive Cable Replacement
Neye ihtiyacın var
  1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Lower Case: adım 1, 1 resimden 1.
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Cable Replacement: adım 2, 2 resimden 1. MacBook Pro 17" Unibody Hard Drive Cable Replacement: adım 2, 2 resimden 2.
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: adım 3, 3 resimden 1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: adım 3, 3 resimden 2. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: adım 3, 3 resimden 3.
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Cable Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Cable Replacement: adım 6, 1 resimden 1.
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Cable Replacement: adım 7, 2 resimden 1. MacBook Pro 17" Unibody Hard Drive Cable Replacement: adım 7, 2 resimden 2.
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: adım 8, 2 resimden 1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: adım 8, 2 resimden 2.
    • Remove the following four screws securing the hard drive cable assembly to the upper case:
    • Two 1.6 mm Phillips screws securing the shield that covers the hard drive cable connector.
    • Two 2.2 mm Phillips screws securing the hard drive cable connector to the upper case.
    • Remove the shield from the logic board.
  9. MacBook Pro 17" Unibody Hard Drive Cable Replacement: adım 9, 1 resimden 1.
    • Use the flat end of a spudger to pry the hard drive connector up and out of its socket on the logic board.
  10. MacBook Pro 17" Unibody Hard Drive Cable Replacement: adım 10, 1 resimden 1.
    • Lift the hard drive cable out of the upper case.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 20,225
