Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the computer over and remove all of the screws that holds together the bottom of the case.
    • Turn the computer over and remove all of the screws that holds together the bottom of the case.
    • The bottom left three screws are longer. Set those aside for reassembly
  2. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  3. Here are the three larger screws.  The smaller ones fit the remaining holes
    • Here are the three larger screws. The smaller ones fit the remaining holes
  4. Delicately lift the case off.  The hard drive is visible.  There is a bracket with two black screws holding it in place.  Remove the bracket and you have access to the hard drive.
    • Delicately lift the case off. The hard drive is visible. There is a bracket with two black screws holding it in place. Remove the bracket and you have access to the hard drive.
    • Remove the interface from the SATA drive and leave the ribbon connected to the mobo.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
jgreenmun
876 İtibar
1 Kılavuz yazıldı
Bir Yorum
do you know if it's posible to upgrade the RAM memory in this particular model ?
Thanks for the guide,
Fons - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 14,502
