Ana içeriğe geç
MacBook Unibody Model A1278 Lower Case Replacement
Neye ihtiyacın var
    1. MacBook Unibody Model A1278 Lower Case Replacement, Access Door: adım 1, 1 resimden 1.
      • With the case closed, place the Unibody top-side down on a flat surface.
      • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Unibody Model A1278 Lower Case Replacement: adım 2, 1 resimden 1.
      • The access door should now be raised enough to lift it up and out of the Unibody.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Unibody Model A1278 Lower Case Replacement, Battery: adım 3, 1 resimden 1.
      • Be sure the access door release latch is vertical before proceeding.
      • Grab the white plastic tab and pull the battery up and out of the Unibody.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Unibody Model A1278 Lower Case Replacement, Lower Case: adım 4, 1 resimden 1.
      • Remove the following eight screws securing the lower case to the chassis:
      • One 3 mm Phillips screw.
      • Four 3.5 mm Phillips screws.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Unibody Model A1278 Lower Case Replacement: adım 5, 1 resimden 1.
      • Using both hands, lift and remove the lower case off the upper case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Is there a way to get replacements for the rubber feet without replacing the entire lower case and access panel?
akwest89 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 68
Her zaman: 29,855
