Ana içeriğe geç
Giriş
Restore sound to your laptop by replacing the subwoofer and right speaker.
  1. With the case closed, place the Unibody top-side down on a flat surface.
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. The access door should now be raised enough to lift it up and out of the Unibody.
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. Be sure the access door release latch is vertical before proceeding.
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. Remove the following eight screws securing the lower case to the chassis:
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. Using both hands, lift and remove the lower case off the upper case.
    • Using both hands, lift and remove the lower case off the upper case.
  6. Dizüstü Bilgisayar Bataryaları
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    Hemen Alışveriş Yapın
  7. Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  8. Disconnect the camera cable by pulling the male end straight away from its socket.
    • Disconnect the camera cable by pulling the male end straight away from its socket.
  9. Use a spudger to pry the optical drive connector straight up off the logic board.
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  10. Remove the two Phillips screws securing the subwoofer to the upper case.
    • Remove the two Phillips screws securing the subwoofer to the upper case.
    • The longer of the two screws is on the right.
  11. The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  12. Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
  13. Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
  14. Lift the optical drive from its right edge and pull it out of the computer.
    • Lift the optical drive from its right edge and pull it out of the computer.
    • The hard drive cable may become disconnected from the logic board when removing the optical drive. Ensure it is connected during reassembly.
  15. Peel back the small piece of black tape covering the right speaker cable. Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case. Lift the subwoofer and right speaker assembly out of the upper case.
    • Peel back the small piece of black tape covering the right speaker cable.
    • Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
    • Lift the subwoofer and right speaker assembly out of the upper case.
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
4 Yorum
I have a Macbook Pro 13, mid-2009, A1278 and the speaker broke it.
Can I put a speaker A1278 a macbook pro 13 mid-2012?
All speakers A1278 model work in any model of Macbook Pro A1278, regardless of the year?
Mrgustavo - Yanıt
I have good sound again, thanks.
2008 MacBook (aluminum).
The hardest part was starting the optical drives hold down screws, my jewelers screwdriver maginetic tip is weak.
Total time was about a half hour.
kqc7011huts - Yanıt
If all you have are Phillips screwdrivers, be very careful with the screws at the split of the bottom case and all of the internal ones. You may have to drop to a Phillips #000 if you don’t have a JIS #00, which appears to be the correct tool for them, based on the actual fit of the bits in my (iFixit) set.
Bill Cole - Yanıt
Hi guys, does anyone know if the subwoofer spare part is the same for the model A1278 from late 2008 and 2009 and so on? thanks in advance
Micro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 Gün: 60
Son 30 Gün: 264
Her zaman: 34,463
