Giriş
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
Aletler
Parçalar
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
10 farklı kişi bu kılavuzu tamamladı.
