Ana içeriğe geç
MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement
Neye ihtiyacın var
  1. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: adım 2, 3 resimden 1. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: adım 2, 3 resimden 2. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: adım 2, 3 resimden 3.
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, Battery: adım 3, 1 resimden 1.
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: adım 4, 2 resimden 1. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: adım 4, 2 resimden 2.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
    • Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
  5. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: adım 5, 1 resimden 1.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the right speaker.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 14,685
