Giriş
This guide will show you how to replace the hard drive cable.
Neye ihtiyacın var
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
Remove the 3.1 mm Phillips screw securing the hard drive cable to the upper case.
19 farklı kişi bu kılavuzu tamamladı.
