Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
Lift the retaining bracket out of the upper case.
When putting the bracket back after replacing the drive, it is easy to put in backwards. If it doesn't seat smoothly, then reverse it and try again.
Lift the hard drive by its pull tab and pull it away from the upper case, minding the cable still attaching it to the logic board.
Remove the hard drive cable by pulling its connector straight away from the hard drive.
Remove the 3.1 mm Phillips screw securing the hard drive cable to the upper case.
Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
Remove the hard drive cable from the upper case.
19 farklı kişi bu kılavuzu tamamladı.
