Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
When replacing your hard drive, you must transfer the Torx screws from the old drive to the new one.
Neye ihtiyacın var
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
Remove the two T6 Torx screws from each side of the hard drive (four screws total).
348 farklı kişi bu kılavuzu tamamladı.
21 Yorum
can i install an ssd instead of a normal hd?
Yes, absolutely. I switched mine out with a Kingston 120GB SSD.
By the looks of it. The Crucial MX100 is explicitly said to be compatible and has SATA III:
Albert -
