Ana içeriğe geç
MacBook Unibody Model A1342 Lower Case Replacement
Neye ihtiyacın var
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: adım 2, 3 resimden 1. MacBook Unibody Model A1342 Lower Case Replacement: adım 2, 3 resimden 2. MacBook Unibody Model A1342 Lower Case Replacement: adım 2, 3 resimden 3.
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
Sonuç
74 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Yanıt
Would the Macbook Pro back cover also fit this?
wow - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 70,242
