Ana içeriğe geç
Macbook 2009-2010 Unibody White Disassembly
Neye ihtiyacın var
  1. Macbook 2009-2010 Unibody White Disassembly, Removing Back Plate: adım 1, 3 resimden 1. Macbook 2009-2010 Unibody White Disassembly, Removing Back Plate: adım 1, 3 resimden 2. Macbook 2009-2010 Unibody White Disassembly, Removing Back Plate: adım 1, 3 resimden 3.
    • Remove the six Phillips head screws with J00 bit.
  2. Macbook 2009-2010 Unibody White Disassembly, Unplugging Battery from Logic Board: adım 2, 3 resimden 1. Macbook 2009-2010 Unibody White Disassembly, Unplugging Battery from Logic Board: adım 2, 3 resimden 2. Macbook 2009-2010 Unibody White Disassembly, Unplugging Battery from Logic Board: adım 2, 3 resimden 3.
    • Then Unplug the battery using a ESD Safe prying tool.
  3. Macbook 2009-2010 Unibody White Disassembly: adım 3, 3 resimden 1. Macbook 2009-2010 Unibody White Disassembly: adım 3, 3 resimden 2. Macbook 2009-2010 Unibody White Disassembly: adım 3, 3 resimden 3.
    • Once battery is unplugged, remove two Philips head screws using J00 bit.
  4. Macbook 2009-2010 Unibody White Disassembly, Removing Hard Drive Part 2: adım 4, 3 resimden 1. Macbook 2009-2010 Unibody White Disassembly, Removing Hard Drive Part 2: adım 4, 3 resimden 2. Macbook 2009-2010 Unibody White Disassembly, Removing Hard Drive Part 2: adım 4, 3 resimden 3.
    • After removing the screws and plastic cover piece, remove the hard drive then unplug from Logic Board.
  5. Macbook 2009-2010 Unibody White Disassembly, Removing The RAM: adım 5, 3 resimden 1. Macbook 2009-2010 Unibody White Disassembly, Removing The RAM: adım 5, 3 resimden 2. Macbook 2009-2010 Unibody White Disassembly, Removing The RAM: adım 5, 3 resimden 3.
    • Locate the RAM Directly above the Hard Drive. Gently push the two snaps away from the RAM cards and gently pull the ram out. You Will do this step again to remove the Second card beneath the first.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Gyoyo
449 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 8,764
