Ana içeriğe geç
Unibody MacBook Pro 15" Glass Replacement
Neye ihtiyacın var
  1. Unibody MacBook Pro 15" Glass Replacement, Prepare a Workspace: adım 1, 1 resimden 1.
    • Set up a clean workspace and gather all supplies. You will need your Macbook Pro, a new screen, a hair dryer, a screen cleaning cloth, and a suction cup.
  2. Unibody MacBook Pro 15" Glass Replacement, Heat the Edges of the Screen: adım 2, 2 resimden 1. Unibody MacBook Pro 15" Glass Replacement, Heat the Edges of the Screen: adım 2, 2 resimden 2.
    • Use a hair dryer to heat the adhesive around the edges of the screen you are removing.
  3. Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: adım 3, 3 resimden 1. Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: adım 3, 3 resimden 2. Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: adım 3, 3 resimden 3.
    • Attach the suction cup found in the iFixit repair kit to the corner of your screen, by gently pressing down until it seals. Lift screen away by pulling up on the suction cup key ring.
  4. Unibody MacBook Pro 15" Glass Replacement, Preparing for the New Screen: adım 4, 2 resimden 1. Unibody MacBook Pro 15" Glass Replacement, Preparing for the New Screen: adım 4, 2 resimden 2.
    • Use a screen cleaning cloth to buff out any marks on your Macbook Pros screen surface.
    • Use a screen cleaning cloth to buff out any marks on the inside of new glass that will be applied.
  5. Unibody MacBook Pro 15" Glass Replacement, Preparing Screen Adhesive: adım 5, 2 resimden 1. Unibody MacBook Pro 15" Glass Replacement, Preparing Screen Adhesive: adım 5, 2 resimden 2.
    • Remove the strips covering the adhesive on the new screen.
    • Heat the new adhesive strips evenly using the hair dryer.
  6. Unibody MacBook Pro 15" Glass Replacement, Applying the New Screen: adım 6, 2 resimden 1. Unibody MacBook Pro 15" Glass Replacement, Applying the New Screen: adım 6, 2 resimden 2.
    • Place the new screen in position. Confirm that the new screen is properly aligned with the edges of the Macbook Pro.
  7. Unibody MacBook Pro 15" Glass Replacement, Attaching the New Screen: adım 7, 2 resimden 1. Unibody MacBook Pro 15" Glass Replacement, Attaching the New Screen: adım 7, 2 resimden 2.
    • Using the screen cleaning cloth carefully press the edges of the screen to seal the adhesive.
  8. Unibody MacBook Pro 15" Glass Replacement, Remove Cover: adım 8, 1 resimden 1.
    • Peel the protective covering off the new screen.
  9. Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: adım 9, 3 resimden 1. Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: adım 9, 3 resimden 2. Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: adım 9, 3 resimden 3.
    • To insure the seal of the adhesive, reheat it again with the hair drying.
  10. Unibody MacBook Pro 15" Glass Replacement, Final Press: adım 10, 1 resimden 1.
    • Finally, use the screen cleaning cloth and carefully press the edges of the screen one more time.
  11. Unibody MacBook Pro 15" Glass Replacement, You did it!: adım 11, 1 resimden 1.
    • Enjoy your laptop with it's brand new Glass!
Sonuç
This guide provides all instructions necessary to dismantle and replace a Macbook Pro Screen.
41 farklı kişi bu kılavuzu tamamladı.
Akh1913
1.282 İtibar
1 Kılavuz yazıldı
Ekip
PIRL Gadget Garage PIRL Gadget Garage üyesi
Community
9 Üyeler
10 adet Kılavuz yazıldı
20 Yorum
How did you know the correct part number for your specific MacBook? Where did you source the glass?
frightanic.com - Yanıt
I sourced my glass this eBay seller: http://www.ebay.com/usr/beetstech?_trksi...
To find the correct part, I followed iFixit's "ID your Mac" prompts in the parts store, then selected the glass panel from the list of compatible parts.
Hope this helps!
Noah Smith -
Is it useful for internal crack
tiffanyts - Yanıt
FYI, OWC (Other World Computing, aka macsales.com) has the 15-inch glass for $25, and the 13-inch for $24:
https://eshop.macsales.com/item/Apple/MB... (15-inch)
https://eshop.macsales.com/item/Apple/MB... (13-inch)
…and I just discovered they even have the 17-inch:
One last comment: get the glass as hot as you can!
jiclark - Yanıt
Does this work for the Late-2013 Retina MacBook Pro (15-inch)?
Brian Shiau - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 130
Son 30 gün: 511
Her zaman: 129,334
