Ana içeriğe geç
Macintosh Classic II Power Board Removal
Neye ihtiyacın var
  1. Macintosh Classic II Power Board Removal, Macintosh Classic II Back Cover Removal: adım 1, 3 resimden 1. Macintosh Classic II Power Board Removal, Macintosh Classic II Back Cover Removal: adım 1, 3 resimden 2. Macintosh Classic II Power Board Removal, Macintosh Classic II Back Cover Removal: adım 1, 3 resimden 3.
    • Here is one of the vintage computers in my possession. It is a Macintosh Classic II M4150. Apple considers this obsolete and " information about these products is no longer updated as of 9/1/98 "
    • On powering it up, It originally greeted me with a checkerboard pattern that quickly converted into this pattern. The checkerboard pattern is/was commonly caused by bad Ram memory. Considering the age of this computer, leaking capacitors are a strong possibility. Time to check.
    • This computer contains a CRT. That means there are some high voltages involved when working on this. Use proper CRT safety while working on it.
    • The cover is held in place by four (4) T-15 screws. Two (2) on the bottom
  2. Macintosh Classic II Power Board Removal: adım 2, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 2, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 2, 3 resimden 3.
    • and two (2) under the top (handle)
    • The bottom ones are easy to remove
    • The top ones are a bit of a challenge due to the depth of the holes.
  3. Macintosh Classic II Power Board Removal: adım 3, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 3, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 3, 3 resimden 3.
    • There was just not enough room to get a good grip on the driver.
    • Luckily this iFixit driver has a hole on the top part. I used a tool to gain some mechanical advantage. While applying downward pressure on the driver, turn the tool to the left to loosen the screw
    • Once loosened, the iFixit extension that came with my set, works perfectly to remove the screw,
  4. Macintosh Classic II Power Board Removal: adım 4, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 4, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 4, 3 resimden 3.
    • Here are the four (4) screws. The two bottom screws are M4X15mm The top screws are those typical found in plastic to sheet metal joints.
    • With the screws removed the cover will slide off.
    • BEst practice is to lay it down and pull the case straight up. It may take some force due to the tight fit and years of storage etc.
  5. Macintosh Classic II Power Board Removal: adım 5, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 5, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 5, 3 resimden 3.
    • Here is what the inside looks like.
    • Remember the High Voltage. Do not touch anything with bare hands etc. Right now it's look but don't touch
    • Power supply (Sweep Board)
    • Flyback Transformer
    • Video card
    • CRT
    • SCSI Hard drive
    • Hard drive on top with the Floppy drive on the bottom
  6. Macintosh Classic II Power Board Removal, Macintosh Classic II CRT Discharge: adım 6, 3 resimden 1. Macintosh Classic II Power Board Removal, Macintosh Classic II CRT Discharge: adım 6, 3 resimden 2. Macintosh Classic II Power Board Removal, Macintosh Classic II CRT Discharge: adım 6, 3 resimden 3.
    • Here is the 9"CRT that we are going to discharge first You are dealing with some High Voltages. Use the proper precaution as outlined in the beginning of this guide
    • Ground screw
    • Anode Cap
    • I use a test lead I had which has Alligator clips or either end. Worked perfect for this. A piece of insulated electrical wire 18 gauge AWG (or similar) will work for this as well.
    • Next is a Flat Tip screwdriver that must italic texthave an insulated handle. No substitution allowed!
  7. Macintosh Classic II Power Board Removal: adım 7, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 7, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 7, 3 resimden 3.
    • Connect one end of the electrical wire to the flat tip screwdriver
    • Connect the other end of the wire to the grounding screw
    • Using one hand only (place the other one in your pocket or behind your back) and the other not anywhere near the chassis, move the screwdriver behind the rubber shield of the Anode Cap. Slide it down until it touches the metal of the Anode. If your CRT was charged, you should now hear a "cracking" sound.
    • Not the sound of an explosion or anything as climactic, but definitely a cracking sound. If your CRT was discharged, maybe because it was unplugged for a awhile etc., you will not hear anything.
  8. Macintosh Classic II Power Board Removal: adım 8, 1 resimden 1.
    • I susually make sure that the screwdriver did touch the metal and using the same precautions as before, move it on the metal for the Anode. Just to ensure it did make proper contact. Usually I wait a minute or two before withdrawing the tool.
    • The CRT is now discharged.
  9. Macintosh Classic II Power Board Removal, Power Board: adım 9, 3 resimden 1. Macintosh Classic II Power Board Removal, Power Board: adım 9, 3 resimden 2. Macintosh Classic II Power Board Removal, Power Board: adım 9, 3 resimden 3.
    • Here is the grounding screw. It also holds the video board ground.
    • Here is the video board
    • Remove the T15 ground screw
  10. Macintosh Classic II Power Board Removal: adım 10, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 10, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 10, 3 resimden 3.
    • To rmove teh video board, pull it stright back. tehre might be some glue/sealant type that you need to remove first. This is different from computer to computer. So, check for that before just pulling on it. Should this be on your computer, carefully use a sharp blade to cut that sealant.
    • One point to be aware of is that under teh video board, is teh weakest point of your CRT. That is the glass niipple that was essnetial for creating this vacuum tube. It is a real weak spot. Should you damage it, air will enter your CRT and it will be permanently damaged. So, be mindful of it when you work on your computer.
    • Next is the SCSI HDD Ribbon cable which needs to be removed.
  11. Macintosh Classic II Power Board Removal: adım 11, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 11, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 11, 3 resimden 3.
    • No lock on it but it is a 50 pin cable and it is rigid. Takes a bit of force to pull it straight up
    • The reason for the SCSI HDD Cable removal is the logic board power cable
    • To remove it, simply push on the tab and pull it straight up
  12. Macintosh Classic II Power Board Removal: adım 12, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 12, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 12, 3 resimden 3.
    • Remove the HDD Power cable
    • On the HDD caddy is a metal clip that functions as a wire holder for the logic board power cable.
    • Bend it slightly away from the caddy to free the wire
  13. Macintosh Classic II Power Board Removal: adım 13, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 13, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 13, 3 resimden 3.
    • One more cable to be removed is the Yoke cable
    • Simply pulling on it will remove it. No lock on this
    • Now its time to remove the Anode. Grab it firmly
  14. Macintosh Classic II Power Board Removal: adım 14, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 14, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 14, 3 resimden 3.
    • and squeeze (lots of force with your thumb downward. That should free up the top notch
    • As you are squeezing and freeing to top notch, tilt the wire at an angle downward
    • and then lift it out. It does take considerable force to squeeze that wire. Do not use any pliers etc, since that may damage the insulation. That may lead to shocking experiences later.
  15. Macintosh Classic II Power Board Removal: adım 15, 3 resimden 1. Macintosh Classic II Power Board Removal: adım 15, 3 resimden 2. Macintosh Classic II Power Board Removal: adım 15, 3 resimden 3.
    • Now remove the two (2) Philips sheet metal screws
    • They are 3mm in diameter and 8mm long
    • Now let's move the power board to the right of the chassis. Do those gently since there is still one cable attached
  16. Macintosh Classic II Power Board Removal: adım 16, 2 resimden 1. Macintosh Classic II Power Board Removal: adım 16, 2 resimden 2.
    • Remove the fan from the power board. The connector has a small tab that needs to be lifted to remove the connector
    • Now the board can be removed without difficutlies. this board looks like it has been recapped. Or Apple used some really high quality capacitors on the original....Nah. I don't think so. Anyhow, it's a clean board with no damage from leaking capacitors etc.
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
785.235 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
33 Üyeler
576 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 67
Her zaman: 713
