Giriş
The Macintosh Classic is a computer mounted in a simple way but with two different types of screws (Torks and Philips) put in the most unattainable places.
Templates
Model Number: M0420 and M1240
Neye ihtiyacın var
Connect a flat screwdriver to the CRT ground cable (black cable attached to the screw) with an alligator cable.
Slowly push the screwdriver under the red suction cup connected to the CRT and touch the metal part with the screwdriver.
Remove the four screws and pay attention to the two hidden screws.
The Floppy lock and Disk go away easily.
Unscrew the two screws that secure it to the chassis and remove the connected cables.
To remove the CRT, simply unscrew the four screws placed at the corners.
To reassemble the device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
