Ana içeriğe geç
Macintosh IIsi Hard Drive Replacement
Neye ihtiyacın var
  1. Macintosh IIsi Hard Drive Replacement, Top Case: adım 1, 2 resimden 1. Macintosh IIsi Hard Drive Replacement, Top Case: adım 1, 2 resimden 2.
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: adım 2, 3 resimden 1. Macintosh IIsi Hard Drive Replacement: adım 2, 3 resimden 2. Macintosh IIsi Hard Drive Replacement: adım 2, 3 resimden 3.
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Macintosh IIsi Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Macintosh IIsi Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: adım 4, 3 resimden 1. Macintosh IIsi Hard Drive Replacement: adım 4, 3 resimden 2. Macintosh IIsi Hard Drive Replacement: adım 4, 3 resimden 3.
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Chris Green
37.026 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.468 adet Kılavuz yazıldı
2 Yorum
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - Yanıt
Is there a way to read the HDD on a PC?
Charles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 3,964
