Ana içeriğe geç
Macintosh IIsi Ram Replacement
Neye ihtiyacın var
  1. Macintosh IIsi Ram Replacement, Top Case: adım 1, 2 resimden 1. Macintosh IIsi Ram Replacement, Top Case: adım 1, 2 resimden 2.
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Ram Replacement: adım 2, 3 resimden 1. Macintosh IIsi Ram Replacement: adım 2, 3 resimden 2. Macintosh IIsi Ram Replacement: adım 2, 3 resimden 3.
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Ram Replacement, Ram: adım 3, 3 resimden 1. Macintosh IIsi Ram Replacement, Ram: adım 3, 3 resimden 2. Macintosh IIsi Ram Replacement, Ram: adım 3, 3 resimden 3.
    • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
    • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
  4. Macintosh IIsi Ram Replacement: adım 4, 3 resimden 1. Macintosh IIsi Ram Replacement: adım 4, 3 resimden 2. Macintosh IIsi Ram Replacement: adım 4, 3 resimden 3.
    • 1st Photo: The RAM Module
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Chris Green
36.978 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.519 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 2,213
