Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Macintosh PowerBook 1400 Series Keyboard Replacement
Neye ihtiyacın var
  1. Macintosh PowerBook 1400 Series Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 3, 1 resimden 1.
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Keyboard Replacement, CD-ROM Drive: adım 4, 1 resimden 1.
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 5, 1 resimden 1.
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 6, 1 resimden 1.
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 8, 1 resimden 1.
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 9, 1 resimden 1.
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 10, 1 resimden 1.
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 11, 1 resimden 1.
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 12, 1 resimden 1.
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 13, 1 resimden 1.
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 14, 1 resimden 1.
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 15, 1 resimden 1.
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 16, 1 resimden 1.
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 17, 1 resimden 1.
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 18, 1 resimden 1.
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Keyboard Replacement: adım 19, 1 resimden 1.
    • Remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sean Bent
41 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011 üyesi
CPSU-FORTE-S11S10G39
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 2,415
