Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the device upside down and then locate the battery latch near the front of the device.
Continue holding the latch then gently pull the battery out of the device.
Slide the latch to the right to release the CD ROM drive.
Continue holding the latch then gently pull the CD-ROM Drive out of the device.
Press firmly on each end of the speaker cover and slide it to the left.
Lift the keyboard up from the back using a spudger(wedge side).
Gently lift the keyboard until only the ribbon cable remains attached.
Remove the six screws from the heatsink using the Philips #1 screwdriver.
Lift the heatsink from the side closest to the laptop screen.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Bir başkası bu kılavuzu tamamladı.
