Ana içeriğe geç
Macintosh PowerBook 165c Daughterboard Replacement
Neye ihtiyacın var
  1. Macintosh PowerBook 165c Daughterboard Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
    FixBot'a Sor
  2. Macintosh PowerBook 165c Daughterboard Replacement: adım 2, 1 resimden 1.
    • Pull the battery toward yourself until it is fully detached.
    FixBot'a Sor
  3. Macintosh PowerBook 165c Daughterboard Replacement, Input/Output Door: adım 3, 1 resimden 1.
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
    FixBot'a Sor
  4. Macintosh PowerBook 165c Daughterboard Replacement: adım 4, 1 resimden 1.
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
    FixBot'a Sor
  5. Macintosh PowerBook 165c Daughterboard Replacement, Lower Case: adım 5, 1 resimden 1.
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
    FixBot'a Sor
  6. Macintosh PowerBook 165c Daughterboard Replacement: adım 6, 1 resimden 1.
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
    FixBot'a Sor
  7. Macintosh PowerBook 165c Daughterboard Replacement: adım 7, 1 resimden 1.
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
    FixBot'a Sor
  8. Macintosh PowerBook 165c Daughterboard Replacement: adım 8, 2 resimden 1. Macintosh PowerBook 165c Daughterboard Replacement: adım 8, 2 resimden 2.
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
    FixBot'a Sor
  9. Macintosh PowerBook 165c Daughterboard Replacement: adım 9, 2 resimden 1. Macintosh PowerBook 165c Daughterboard Replacement: adım 9, 2 resimden 2.
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
    FixBot'a Sor
  10. Macintosh PowerBook 165c Daughterboard Replacement, RAM and PSRAM Expansion Card: adım 10, 2 resimden 1. Macintosh PowerBook 165c Daughterboard Replacement, RAM and PSRAM Expansion Card: adım 10, 2 resimden 2.
    • Locate and lift ram card directly up until connector releases.
    • Move the card back and forth gently if the connector does not release immediately.
    FixBot'a Sor
  11. Macintosh PowerBook 165c Daughterboard Replacement: adım 11, 2 resimden 1. Macintosh PowerBook 165c Daughterboard Replacement: adım 11, 2 resimden 2.
    • Locate and lift the PSRAM expansion card vertically until connector releases.
    • If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
    • The PSRAM expansion card is an optional component, and may not be included in all devices.
    FixBot'a Sor
  12. Macintosh PowerBook 165c Daughterboard Replacement, Daughterboard: adım 12, 1 resimden 1.
    • Use T8 torx screwdriver to remove four, 7.7mm long screws from the perimeter of the daughterboard.
    FixBot'a Sor
  13. Macintosh PowerBook 165c Daughterboard Replacement: adım 13, 1 resimden 1.
    • Life the daughterboard directly up to remove it from the connector.
    • If the daughterboard does not easily release from the connector, gently jostle it back and forth as you lift up.
    FixBot'a Sor
Sonuç
Adam
1 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G3
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 62
Her zaman: 1,692
