Ana içeriğe geç
Macintosh PowerBook 165c Display Replacement
Neye ihtiyacın var
  1. Macintosh PowerBook 165c Display Replacement, Display: adım 1, 1 resimden 1.
    • Orientate the computer right side up and open the display case to reveal the display.
    • Use a plastic opening tool to remove the two small plastic plugs located on the display case just below the display.
    FixBot'a Sor
    Yorum Ekle
  2. Macintosh PowerBook 165c Display Replacement: adım 2, 1 resimden 1.
    • Use a T8 torx screwdriver to remove the two, 7.7mm long screws that were revealed by removing the plastic plugs.
    • Twist counterclockwise to remove the screw.
    • Caution: Once the screws are removed, the display is only held by two screws. Handle delicately.
    FixBot'a Sor
    Yorum Ekle
  3. Macintosh PowerBook 165c Display Replacement: adım 3, 1 resimden 1.
    • Grip the two bottom corners of the plastic display cover and gently pull towards yourself so that the display cover rotates about the top of the display case.
    • The display cover should release from top.
    • Remove the display case.
    FixBot'a Sor
    Yorum Ekle
  4. Macintosh PowerBook 165c Display Replacement: adım 4, 1 resimden 1.
    • Locate the black connector on the right of the display. The connector can be identified by the pink, light blue, and white wires protruding from its side.
    • Remove the black connector from the circuit board by pulling it away from its adapter.
    FixBot'a Sor
    Yorum Ekle
  5. Macintosh PowerBook 165c Display Replacement: adım 5, 1 resimden 1.
    • Using a T8 torx screwdriver, remove the four, 10.8mm long screws from the corners of the display.
    • Caution: The display is no longer supported and must be handled with care.
    FixBot'a Sor
    Yorum Ekle
  6. Macintosh PowerBook 165c Display Replacement: adım 6, 1 resimden 1.
    • Carefully tilt the display downwards and rest it on the keyboard.
    FixBot'a Sor
    Yorum Ekle
  7. Macintosh PowerBook 165c Display Replacement: adım 7, 3 resimden 1. Macintosh PowerBook 165c Display Replacement: adım 7, 3 resimden 2. Macintosh PowerBook 165c Display Replacement: adım 7, 3 resimden 3.
    • Locate the orange ribbon cable on the back of the display.
    • Open the white tab fastener by pulling it outward.
    • Remove the orange ribbon cable by gently pulling it away from the opened tab fastener.
    • The display is now free.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jason
110 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G3
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 53
Her zaman: 2,948
