Ana içeriğe geç
Macintosh PowerBook 165c Lower Case Replacement
Neye ihtiyacın var
  1. Macintosh PowerBook 165c Lower Case Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
    FixBot'a Sor
    Yorum Ekle
  2. Macintosh PowerBook 165c Lower Case Replacement: adım 2, 1 resimden 1.
    • Pull the battery toward yourself until it is fully detached.
    FixBot'a Sor
    Yorum Ekle
  3. Macintosh PowerBook 165c Lower Case Replacement, Input/Output Door: adım 3, 1 resimden 1.
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
    FixBot'a Sor
    Yorum Ekle
  4. Macintosh PowerBook 165c Lower Case Replacement: adım 4, 1 resimden 1.
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
    FixBot'a Sor
    Yorum Ekle
  5. Macintosh PowerBook 165c Lower Case Replacement, Lower Case: adım 5, 1 resimden 1.
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
    FixBot'a Sor
    Yorum Ekle
  6. Macintosh PowerBook 165c Lower Case Replacement: adım 6, 1 resimden 1.
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
    FixBot'a Sor
    Yorum Ekle
  7. Macintosh PowerBook 165c Lower Case Replacement: adım 7, 1 resimden 1.
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
    FixBot'a Sor
    Yorum Ekle
  8. Macintosh PowerBook 165c Lower Case Replacement: adım 8, 2 resimden 1. Macintosh PowerBook 165c Lower Case Replacement: adım 8, 2 resimden 2.
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
    FixBot'a Sor
    Yorum Ekle
  9. Macintosh PowerBook 165c Lower Case Replacement: adım 9, 2 resimden 1. Macintosh PowerBook 165c Lower Case Replacement: adım 9, 2 resimden 2.
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jason
110 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G3
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 1,495
