Ana içeriğe geç
Macintosh Powerbook 5300cs Hard Drive Replacement
Neye ihtiyacın var
  1. Macintosh Powerbook 5300cs Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 2, 1 resimden 1.
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Hard Drive Replacement, Keyboard: adım 3, 1 resimden 1.
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 4, 2 resimden 1. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 4, 2 resimden 2.
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 5, 3 resimden 1. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 5, 3 resimden 2. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 5, 3 resimden 3.
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 1. Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 2. Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 3.
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 7, 1 resimden 1.
    • With a Torx #9 screwdriver, remove the three .30 in. screws that hold the metal frame in place.
  8. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 8, 3 resimden 1. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 8, 3 resimden 2. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 8, 3 resimden 3.
    • Remove the metal chasis that holds the hard drive.
  9. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 9, 1 resimden 1.
    • In order to remove the hard drive, remove the four .22 in. screws circled in red found on both sides of the metal chassis with a Torx #9 screwdriver.
  10. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 10, 2 resimden 1. Macintosh Powerbook 5300cs Hard Drive Replacement: adım 10, 2 resimden 2.
    • Pull the hard drive out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ronan
63 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-1, Regan Fall 2011 Cal Poly, Team 6-1, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,785
