Ana içeriğe geç
Macintosh Powerbook 5300cs RAM Replacement
Neye ihtiyacın var
    1. Macintosh Powerbook 5300cs RAM Replacement, Battery: adım 1, 1 resimden 1.
      • The battery compartment is located in the front-right side of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Macintosh Powerbook 5300cs RAM Replacement: adım 2, 1 resimden 1.
      • To insert the battery, gently slide it into the compartment until it clicks in place.
      • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Macintosh Powerbook 5300cs RAM Replacement, Keyboard: adım 3, 1 resimden 1.
      • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
      FixBot'a Sor
      Yorum Ekle
    2. Macintosh Powerbook 5300cs RAM Replacement: adım 4, 2 resimden 1. Macintosh Powerbook 5300cs RAM Replacement: adım 4, 2 resimden 2.
      • Carefully pull up on the front of the keyboard to pop it out from the case.
      • Then slide the back out so the keyboard becomes nearly free.
      FixBot'a Sor
      Yorum Ekle
    3. Macintosh Powerbook 5300cs RAM Replacement: adım 5, 3 resimden 1. Macintosh Powerbook 5300cs RAM Replacement: adım 5, 3 resimden 2. Macintosh Powerbook 5300cs RAM Replacement: adım 5, 3 resimden 3.
      • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
      • Pull the keyboard out and repair or replace as needed.
      FixBot'a Sor
      Yorum Ekle
    1. Macintosh Powerbook 5300cs RAM Replacement, RAM: adım 6, 3 resimden 1. Macintosh Powerbook 5300cs RAM Replacement, RAM: adım 6, 3 resimden 2. Macintosh Powerbook 5300cs RAM Replacement, RAM: adım 6, 3 resimden 3.
      • Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ronan
72 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-1, Regan Fall 2011 Cal Poly, Team 6-1, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G1
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 1,336
